Turbo Timer
Turbo Timer
Hey guys, I just wanted to ask if its possible to hard wire a turbo timer in our SC's. Im sure its possible, but I cant find any real info. From searching I see that there is no harness that you can use, but you would NEED to hard wire it yourself.
Is this guide all I need?
https://www.clublexus.com/forums/sho...d.php?t=152929
Well I was going to pick up a cheap used older model Blitz timer. I dont know the model.. Im guessing I can make any timer work, I would just need to know which were the correct wires to connect. Right?
the white wire is constan 12 volts which attaches to the red on the turbo timer harness
the black yellow is ON number 1 which attaches to the blue wire on the harness
the black orange is ON number 2 which attaches to the green wire on the harness
this is what i did it works great the wires from timer to timer are pretty much the same
