Traction control
Traction control
Hello,
I purchased 1999 LEXUS SC400 without traction control. I need info if is possible mount this system to my car.
I welcome any help...
Zombie Slayer
Don't think it's possible as the traction control on the SC is fairly complicated. First, the throttle body is different as it has 2 butterflys. Next, the TC system is plumbed into the brake lines to apply braking pressure to the wheel that has lost traction. I'm sure this also wires into the computer somewhere or some additional computer.
My thought is that if it didn't come with it....you ain't gettin it.
Zombie Slayer
If I could, I'd sell you mine. I turn it off every time I turn on the car.
I find it beneficial only in the snow. And not to stop from getting stuck, only to keep the back end from sliding out a bit under easy acceleration while already moving.
I have list of parts which I need for mount:
1. Master cylinder
2. Traction control accumulator/pump
3. Throttle body with traction control butterfly and TPS sensor
4. All hydraulic lines and fittings
5. Traction control ECU
I need only instruction for apply...
1. Master cylinder
2tirefire
12
01-21-20 07:12 AM
JM51526
Road Course and Auto-X
04-14-15 03:07 PM
