Writeup on installing GM TH400 automatic transmission
#33
Looks good. I understand the concern on the converter issue, however for my car that much "work" on the tunnel is too much. I did have a question though. The Flexplate you got is it SFI approved, or just a re worked stock one? Do you have any pictures?
THanks
Danny
THanks
Danny
#34
I would have never spent that much for this car, but I switched to a liberty 5-speed in the drag car and decided to use this in the SC. I tried selling the kilgore, but it wasnt going to sell unless I lost my ***, and I could not justify not using such an impressive piece of equipment. AFAIK i will be the first to try one of these trans on an import motor.
This trans is supposed to be good for 1000+ hp. He told me a 3400 lb car is running in the low 8's on this trans.
#36
I can run a SFI flexplate, but the one I got is a custom piece from boostwerx. I believe I can run any SFI GM flexplate if I wanted to though with DaveH's adapter.
#38
i am waiting on the parts to be sent out, DaveH is waiting on the machine shop to get them done. pics as soon as i get the pieces!
#40
The DaveH adapter kit is $750, and uses a stock GM torque converter and toyota flexplate. IDK where you got $3500 without the transmission, thats kinda inflated by $1500.
CaliTRDSC
Performance & Maintenance
10-24-13 07:55 AM
