Question about an issue i had
Old 11-06-06, 08:04 PM
97blacksc3
97blacksc3's Avatar
Default Question about an issue i had
My car died today and i pulled over. When i popped the hood i noticed that my serpentine belt was loose to the point where i can take it off with my hand. I started it back up and it made a loud squeaking sound. Is the tensioner bad? Thats what i would think but is there anything else i should check?
Old 11-08-06, 12:13 PM
97blacksc3
97blacksc3's Avatar
anybody? I dont want to buy the wrong part.
Old 11-10-06, 03:03 PM
shlounek
shlounek's Avatar
Did you check your crank pulley, sometimes that Ring around the crank pulley seperates it holds ur belt at the bottom, maybee it went loose, fell on the road and the belt didnt go loose.
Or maybee your belt is really old and simply stretched out..
Old 11-10-06, 05:03 PM
BiZ
BiZ's Avatar
When you put it back on how did the tensioner feel? Did it have any resistance? Or was it sloppy?
Check your belt against a new belt to see if it has stretched out too far. Although I have never seen a belt stretch to the point of slipping off, they usually just break. Also check what Shlounek suggested. That belt wraps around several pullies so it could be any one of them. The squeeling could be the bearings in one of the accessories or tensioner.
I have a feeling that those "Lexus" tensioners are pretty expensive. Hopefully you can get one for a "Toyota" for cheaper.
4ringsa6
09-05-17 11:33 AM
kez
07-24-10 06:41 PM
curtsutton
10-31-09 05:55 AM
snidehocke
02-11-08 06:21 PM
kaotiq
24
03-18-05 07:23 AM
Quick Reply: Question about an issue i had
