1JZ Water Pump
Ok Guys,
I _did_ search (1JZ Water Pump) but couldn't find what I was looking for.
I think the water pump is going out on my 1JZGTE.
I thought I'd poke around on our forums here as well as over at Supraforums, to find out if the 1JZ needs a unique water pump.
I have not been able to get a definitive answer.
Some people say that the 2JZGTE water pump fits, but you need the 2JZGTE pulley.
Some people say you also need a housing to make this work.
Some people start talking about eliminating the hyrdo fan when swapping the 2JZ water pump into the 1JZ.
For once and for all, let's get this in one place:
Can I replace my water pump by simply (and I know it's not a simple task) putting in a 2JZGTE pump with the 2JZ pulley?
What about this housing some people were talking about?
What's the right choice: new Toyota or rebuilt from AutoZone/Advantage/O'Reilly's, etc?
Can I re-use my existing belt? (provided it's in good condition)
Is there an advantage to just changing all pulleys in there with the Greddy 2JZ pulleys, while I'm in there (and since I have to pay for a pulley anyways)?
Anything else I should work on while I'm in there?
I apologize if this has been covered in detail before, but I could not find it.
Thanks in advance,
Marcus
Thanks in advance,
Marcus
Thanks Kaosman.
Anyone else have anything to share?
I'll look this weekend to see if i've got a hydro fan or not, and make sure the leak is from the water pump.
Please share any more information or experience on 1JZ water pump replacement!
Thanks,
Marcus
Thanks,
Marcus
you most likely have the hydro fan and the pump for it is just expensive...i have the same problem but with the jdm 2jzgte...the dealer (jeff at jay marks toyota) i talked to said it would be cheaper if i convert or look for an use one on the forums...give jeff a call and he can give you all your options plus they carry a lot of 1jz parts 800-327-2087
good luck
good luck
