So I finally seafoamed my sc400
the button on the shift stalk for the od is broken so Im pretty much in od all the time. Not sure if this has to do with my power hesitation I was having.
any way I seafoamed my car today to get the throttle responce back. It made a bit of a difference then I put some auto lite plugs in gapped at .45, wires were decent tanaka I think are these stock. this made a difference as well. the plugs I pulled were denso plugs and looked quite old.
after a initial spin around town I was not too thrilled then I put the button for pwr on and made a huge difference. I want to drive with the ect power button on all the time, is this fine for the car? Im at half tank and only 120 miles . i put a can of techron chevron as well. timing belt looked great no signs of wear or cracking etc.
that was my friday night adventure, next I plan on spraying the TB clean and the maf sensor and idle air motor if I can find it.
Banned - could not follow forum rules
The seafoam is sucked in threw the brake vacume line and directly into the combustion chambers if done correctly...This will clean the years of Carbon build up due to running the EGR system, clouds of smoke should emit when this is done..Spark plugs could get fouled so changing is a good idea.....\\
However, I don't see why you would need to change the oil unless you run the seafoam directly in with the oil...I don't think it is like power in a bottle either, so most should not expect big power gains from this procedure...Do the Seafoaming experts agree with me?
I did it about 3 times. I did an oil change with all 3 of the times I used Seafoam. First time I remember, my friend told me it will produce a lottttt of smoke if my car was a Seafoam virgin. I was like "neh, couldn't be THAT bad". But dude, right when I started it up and gassing it, my whole neighborhood was up in smoke. My neighbor asked me if I needed any help lol. I said no I was doing something. Kinda feels bad for messing up the atmosphere.
I concure...Major smoke screen...All those years of protecting the invironment with EGR system is released in one sea foaming session...Mushroom cloud city, ozone depletion, global warming, polar ice cap melting, etc...It gets ugly.....
I think there is something wrong with my car, after the seafoam it ran ok for that day, I drove it again today and same thing. I smash the gas pedal all the way to the floor wide open throttle and it takes 3-4 seconds before it finally realizes that I want to go fast then takes off. It is not breaking up or misfireing etc, new plugs, fuel filter, air filter, seafoamed, new oil and filter, cleaned throttle body, new belt. What else can I try?
how can I check to see if it is the coil/s
clogged cat?
maf or tps sensor issues?
any help would be great! just had the car for about 3 weeks now 106k miles.
clogged cat?
clogged cat?
clogged cat?
thanks guys, that really sucks about that lag however, atleast I know not to throw parts at it now unnessacerily. I was going nuts thinking there was something wrong. I never felt such a lag in any auto I drove what the heck was lexus thinking?
The guy who I got it from said his 93 SC400 was the same way, I just thaught it was a cover up statement to sell the car.
Change out your weak stock torque converter and you will get instant throttle reponse from idle, no lag what so ever....I can do a burn out now with the Precision Industries Dragon Torque Converter from idle....Floor the gas from a dead stop and both fat rear tires will spin out with no nos....Torque converter is everything on these automatic SC's...
