My 1JZ carnage from last night
Taking out the busted 1JZ at my shop tonight...
http://www.1jzgte dot us/pics/albums/IMAGE_097.jpg
http://www.1jzgte dot us/pics/albums/IMAGE_098.jpg
http://www.1jzgte dot us/pics/albums/IMAGE_099.jpg
http://www.1jzgte dot us/pics/albums/IMAGE_100.jpg
http://www.1jzgte dpt us/pics/albums/IMAGE_101.jpg
Rolling deep with 4 SC's, 3 of which are 1JZGTE.
Chino, most likely pre-ignition is the problem here. When you changed the plugs did you change heat ranges or plug style?
Pre-ignition is when something lights the mixture before the plugs fire. This is very commonly a glowing hot spark plug. Too hot of a plug is a big no no on a turbo car. When the mixture starts burning before timed ignition the charge pressure increases very fast and the piston is still going up and compressing further. The heat and pressure created can MELT pistons and plugs. The center of melted pistons can blow away and now you are pressurizing the crankcase. This pressure tries to escape everywhere including blowing oil out of every place it can (like the oil fill cap and PVC).
Your short block is toast.
You can probably salvage everything else.
What about the 1jzgte head and turbos on a 2jzge short for a 1jz/2jzgte hybrid? Simple way to gain half a liter.
thats why i like you... you sound like me and chino talking to some people last night.
look whos talking
haha, thats not my motor... that is Ric's car with my front bumper on it..... He still has a few more things to do before its running... As for me, i took a break from the car today.. will get back on the ball tomorrow and get the n/a motor in so i have something to drive. after that ill take apart the 1jz and see what went wrong
got the intake manifold and engine harness off the motor
cylinder 5 intake valves. oil soaked
cylinder 1 intake valves. not too much oil but its there
results!
can you guess the weakest link???
pic of a good piston-
1jz-gte: The meltdown! (the bad piston)
Bore + strokeable????
I can see the rings through that hole They're in tact from what i see!
guess which one is cyl. 5
cyl # 5-
cyl # 5-
