My 1JZ carnage from last night
So I was out and about last night cruising around tampa/clearwater/st. pete area. Met up with a few MKIII guys, went to a few meets. On the way home me and another member with a single'd 1jz mkiii play with each other a few times.
The last time he let off in 3rd. I kept going. Got up to about 120-125ish and the car stopped going. Started to putter and felt like it didnt want to shift. Wouldnt really boost past 4psi. So i slow down and get engulped in a cloud of smoke. Then im like ****. Pull over. See oil around the filler cap and downpipe area.
Got home a little after 5am after waiting almost 2 hours for a flatbed to bring it back to the wifeys apartment. I pulled the plugs this morning to do a compression test and found oil on ALL the plugs, number 5 tip and electrode looks like it melted?? Started the compression test on cyl 1 and saw oil shooting strraight up from the spark plugs holes... I had wifey turn it over and looks like its coming from cyl 4??
Thats about as far as i got with it. Ill trailer it back home to orlando sometime in the next few days so I can tear it apart to see what i ****ed up...
Not 2 bad considering it lasted atleast about 3 years on the twins.
Looks like oil came out of the filler cap?
Found oil on the downpipe as well...
ALOT less smoke than compared to last night
Cylinder #5 plug. Just replaced a week ago.
This is what happened when I tried to do a compression test
Look at the oil bouncing off the hood.
a few vids of the fun i had with that motor:
http://media.putfile.com/preview01
http://videos.streetfire.net/player....C-32CACFF6113D
http://videos.streetfire.net/player....E-37BAABF31C50
almost 3 years of beating on that motor with the stock twins at 1bar, driving it 100 miles to tampa and 100 miles back 3-4 times a week since march this year, making high speed pulls on the highway, running it down the 1/4 mile, doing 1 minute plus long burnouts, etc etc. It was well worth the fun i had it it. Time to come back stronger!
clublexus readers... get ready for the first ever 1JZ to 2JZ-GE swap ever. it will be alive again in about 2 days.
malik, do you really need a ride from the orlando airport? when are you coming in?
