1992 sc300 5spd sudden loss of power on highway!
I was going about 80mph this morning in 5th gear. Suddenly, my accelerator went dead and became unresponsive and the car began to slow down. I managed to pull over to the shoulder and shift to neutral, when the car stalled as it approached 500 rpm and lower. I got it to start right away and the problem had disappeared and my accelerator worked once again.
I just had plugs/rotor/cap/wires done and they're all lexus oem parts. Other than this event, the car ran perfectly fine since the tune-up. Any idea of what could be going on? Can resetting the ECU and cleaning the throttle body help this problem is there a sensor that could have triggered the loss of the accelerator?
The linkage seemed fine and I do not think the throttle was stuck closed or open, because once I restarted the car, it was completely fine.
Car has 192,xxx miles and I'm running 93 octane.
so it could be:
1) obstructions in air passage (throttle body, intake)
2) may need a good 'seafoaming'
3) fuel pump ecu
4) fuel pump
5) fuel filter
missing any?
I know many of the questions I have been asking on the forums are questions that have been asked/answered before. However, the only reason I ask as I did above is to gather all the possible problems just to better equip my mechanic to handle it.
Maybe there should be a FAQ for the stalling issue; the information is def there, but the search function in this forum isn't necessarily the best.
TIA
3) fuel pump ecu
4) fuel pump
5) fuel filter
missing any?
TIA
jacobsc300
Performance & Maintenance
06-03-15 02:12 PM
