car driving slowly, pre-cat's are red hot
Old 11-19-06, 12:31 AM
sean9975
sean9975's Avatar
Default car driving slowly, pre-cat's are red hot
almost done with outside of car!(pics soon). during constuction i started car regularly. but i still have a problem. my car drives slow as hell. barly any response from petal. and my exhaust (by the pre-cats) is red hot. HELP ME PLEASE!!!! stock sc400
Old 11-19-06, 01:01 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
First, please use the engine forum.
Secondly, "CRAP" is not an appropriate thread title for finding the help you need.
I've moved and retitled the thread in hopes someone can help you. Sounds like you are running very rich with lot's of fuel burning in the exhaust.
Old 11-19-06, 01:11 AM
sean9975
sean9975's Avatar
sorry & thanx!
Old 11-19-06, 01:33 AM
Jewcano
No Sir, I Don't Like It
Jewcano's Avatar
Post up PICS of this ride.
Old 11-19-06, 01:37 AM
sean9975
sean9975's Avatar
after paint
Attached Thumbnails car driving slowly, pre-cat's are red hot-sean-s-670.jpg
Old 11-19-06, 01:39 AM
sean9975
sean9975's Avatar
this is about a month ago.more pics 2day
Attached Thumbnails car driving slowly, pre-cat's are red hot-0922061709.jpg
Old 11-19-06, 11:09 AM
Sly Guy Yu
Sly Guy Yu's Avatar
ur cats are clogged. Get some new cats and it'll let the air flow better and give you more performance.
Old 11-19-06, 11:14 AM
95 Integra
95 Integra's Avatar
BTW, is it just me or does the side of your car look like an old late 60s mustang?
Old 11-19-06, 02:22 PM
sean9975
sean9975's Avatar
how much should i be paying for cats
Old 11-19-06, 03:31 PM
wildrice09
wildrice09's Avatar
Depends what your looking for. If you want performance I would suggest going with Magnaflow highflow cats. Their about 100 bucks for one, but they will definately keep restriction down and make sure you pass the sniffer.
Old 11-20-06, 01:49 AM
sean9975
sean9975's Avatar
thanx guys. CL rocks
Old 11-20-06, 07:59 AM
BiZ
BiZ's Avatar
Before you run out and buy new cats please inspect your ignition system first. I had a very similar problem about a month ago. My car felt like it was running on half the cylinders and when I got home I looked underneath and the cats were glowing red hot. I too suspected the cats were clogged. But my problem ended up being the drivers side coil wire. It got pinched inbetween the plastic cover and all of the movement and vibrations had worn through the insulation on the wire thus exposing it to the elements. With this wire failing half of the cylinders were not firing. Which then sent raw fuel into the cats where it was burned up causing the cats to glow red. That problem also killed the O² sensor on the drivers side.
Also the magnaflow cats are not a direct replacement the same goes for the "universal" cats. You will need to have some exhaust work done in order to have them installed.
This site has good prices on magnaflow cats and they also have direct fit replacement cats at good prices:
http://shop.catalyticonverters.com/b...converter&my=1
Good luck
Old 11-21-06, 01:53 AM
sean9975
sean9975's Avatar
thanx BIZ. i will inspect 2day
Old 11-21-06, 06:52 PM
joshthorsc
joshthorsc's Avatar
My bro's SC400 had the exact same problem. He replaced both the ignition coils and his car ran fine after that.
Just buy the ignition coils from a auto parts store(my bro got his at Napa) and replace them. If it doesn't fix the problem then return them for a refund but most likely I suspect it's the ignition coils.
~Josh
Old 11-22-06, 02:50 AM
sean9975
sean9975's Avatar
i didnt have a ot of time to check yesterday but i did check the drivers side wires and they were ok. 2 day i will chek the passenger side and igniton coils. thanx joshthorsc. will do 2 day.CL ROCKS
Quick Reply: car driving slowly, pre-cat's are red hot
