1JZ In.... car will not start, need help
OK ladies and gents, so after a long week of working on the engine I finally finished up the whole swap, extended wiring etc. So comes the big day and no ignition the car is dead:
- Already grounded the pin on the ECU for the Neutral Start Switch
- Ran a new wire direct from the pin to the 8 pin connecter and Black wire for the ignition
so when the key is in the ON position, the loud walbro can be heard, when the key turned the Ignition relay click can be heard but no start.
Tomm I will try a rolling start to see if I can get it to start up, anyone had these issues.
Thanks
Thanks
Resize the pic.
Anyway, so your doign an auto-manual swap as well? Using a MT or AT ecu? This may help you, post #17 is the neutral safety switch.
https://www.clublexus.com/forums/sho...ght=manual+ecu
its an AT ECU, so i grounded the NSW switch, but still no start but my fuel pump works.
So I found the signal wire for the starter in the engine bay and car started up but now I will need to re-wire the 3 pin connector going to the starter from the engine fuse box
so which wire goes to the POS Signal wire from the starter relay
RED/BLACK
RED/BLACK(thinner wire)
WHITE
BLACK
RED/BLACK
WHITE
BLACK
emoFTW
Performance & Maintenance
12-05-12 05:51 PM
