LS1 ? In a SC400/300 has it been done ?
Old 12-03-06, 01:35 PM
  #46
WDoherty
WDoherty's Avatar
true that, i'm a fan of both jibby, i'd like to see someone try some n/a sc400 performance, i'm really glad your trying the cams, then i'd like to see an ls1 swaped sc400, there are pros and cons to both.
Old 12-03-06, 01:40 PM
  #47
MJHSC400
MJHSC400's Avatar
I hope they increase the overlap a good bit, cuz we're kinda screwed on overlap with the 1UZ--
Impossible to just use a cam gear and tweak it --
Old 12-03-06, 01:48 PM
  #48
WDoherty
WDoherty's Avatar
if you can get the e-manage ultimate break the rev limiter on the sc400 you'd be making a huge break through for sc400 performance, i've never heard of a piggyback doing it.
Old 12-03-06, 02:00 PM
  #49
okcfunky
okcfunky's Avatar
Go find a salvage Fbody so you can grab its T56 and potential goodies to see if the accessory belt and oilpan work better for ya.
However, if your wanting to do it big, wait for the LSX block(should be around 4K in shortblock form i think), you'll be able to get around 2500 horsepower out of it turbo'd, supercharg'd, or mega cubed to 500+. But going that route you'll want a TH400 beefed up and a 9"
Old 12-03-06, 02:05 PM
  #50
MJHSC400
MJHSC400's Avatar
I'm just going by what their specs suggest, and split second also sells some signal clamps that claim to be capable of the same thing--
It basically just reads the tach signal and when it reaches the preset you program it with just before fuel cut, it sends a clamped signal, where it tells the ecu it's turning 6300, and the piggy back keeps feeding it fuel under WOT operation up until it reaches it's fuel cut at 8000 [kaboom] rpms-- I'd keep it around 7500 for fuel cut myself--
While it's revving up there or at any rpm under WOT-- the piggyback is operating the fuel/timing according to it's wot pre-tuned map you already told it to use-- so no fuel cut, and the piggyback can read the rpms and send the correct fuel/timing control until 7500 rpms....
This would of course need some sort of tranny controller to raise shift points or it would be useless...
So the ecu just thinks the motor is revving a steady 6300 anywhere above that rpm due to the signal clamp-- and the motor keeps getting fuel, as the Piggy Back just keeps modulating the injectors itself--
The ONLY thing I forsee a problem with is the stock tach ---- It seems to me that it would just sit at 6300 or so until the revs come back down--
You could:
A: not worry about it, as it's not going to blow if you tuned it right and don't keep it up there too long at a time
B: get an aftermarket tach-- Which would suck since the factory unit goes to 8k
Old 12-03-06, 03:27 PM
  #51
jibbby
Banned - could not follow forum rules
jibbby's Avatar
The best piggy back ECU available is the SMT6 and even better the SMT7 from my reads.. Those expensive piggy-back ECU's have just about every option you would want and need and can practically wipe your **** for you after you take a dump...
WD - I did not know I had a fan base...Thanks bro...you da man....
Old 12-03-06, 05:55 PM
  #52
2GTSVETTE
2GTSVETTE's Avatar
aw man... My alternator went out today in my SC400, and its snowing tomrrow...dam looks like ill be using public transportation, There is no way ill drive my vette in the snow. I rather walk
Old 12-03-06, 06:51 PM
  #53
WDoherty
WDoherty's Avatar
yo jibby, i'm a fan of both means i'm a fan of both an ls1 swap or some 1uz n/a power. but i am glad your doing what your doing.
Old 12-03-06, 09:24 PM
  #54
2GTSVETTE
2GTSVETTE's Avatar
You could:
Old 09-23-07, 04:42 PM
  #55
cartechpr
cartechpr's Avatar
None of these problems arise with the ls1 as you can reprogram the ECU.. i know the ECU has a tach output multiplier which you can modify. I am pretty sure you could make the ECU control the stock gauges.
Old 09-28-07, 07:08 AM
  #56
NoLongerA13bFan
NoLongerA13bFan's Avatar
I have ridden in a pair of TT Z06s and the power and torque at 12 psi on pump gas is incredible. The cars make 7xx whp and the same torque and feel infinitly faster than the 900 whp Supra I have ridden in. For the money a boosted LS motor is hard to beat. I think that it would be a sweet swap to try if you had the time and money.
Old 09-29-07, 10:56 PM
  #57
Bean
Bean's Avatar
Holy dead thread batman. Not to mention the misinformation; how did I miss this one?
Old 05-23-10, 08:26 AM
  #58
EDTUN3R
EDTUN3R's Avatar
Originally Posted by 2GTSVETTE
A LS1 with a remoted mounted turbo has great results.
I am good buddys with the CEO of STS turbos so i might be doing a system from him...
LS1 Camaro/Firebird
Performance Results
Boost: 5 psi
Rear Wheel Horsepower: 414
%'d increase: 30%
Rear Wheel Torque: 450
%'d increase: 35%
Boost: 8 psi
Rear Wheel Horsepower: 508
%'d increase: 59%
Rear Wheel Torque: 548
%'d increase: 64%
1/4 mile time reduction: ~1 second
What Size Turbo Is That?
tenshu2k
SC- 1st Gen (1992-2000)
22
04-30-11 09:19 AM
vegas_sc4
15
01-26-11 10:07 AM
thebadz32
09-10-07 02:39 PM
zygotesoup
20
07-04-07 10:50 AM
92S0ARER
30
01-17-07 09:00 AM
Quick Reply: LS1 ? In a SC400/300 has it been done ?
