Need help on CLutch & Flywheel recommendations
What clutch kits and flywheels do you guys recommend? I am thinking of going with the SPEC stage 3 with a 6 puck, so later I would not have to change it when I go turbo. Does anyone have any experience with this clutch kit? I'm not too sure what flywheel to go with, so any info would be great.
FWIW...We use the Spec clutches a lot on the 3SGTE in MR2 builds. We've been very happy with them thus far. Also, they make a great flywheel.
I don't know what your power goals when you go turbo, but the W58 doesn't like much power being run through it.
6 puck would be really harsh on your leg and the W58 and not to mention annoying everytime you want to start from a standstill,
I would go with remanufacturing your OEM clutch to a KEVLAR composite, this material is amazing I did mine for 225.00 with a new throw out bearing and they will re-surface your flywheel also.
Ya I've heard that the mr2 guys love the SPEC clutches. Since the 6 puck would be too harsh on my tranny, should I go with the SPEC stage 2+:
STAGE 2+ - For all modified engines making more torque than the stage 2 can support. Maintains stage 2 feel for good daily drivability and offers very good wear characteristics, but provides a higher torque capacity. High clamp pressure plate, composite multi-friction carbon-kevlar material, high torque sprung hub and disc assembly, bearing and tool kit.
Torque Rating: 340 ft/lbs.
As for the SPEC flywheel, there has not been a lot of posts about flywheels. I've read that one guy had to redrill something on the flywheel. I would like to know are flywheels pretty much the same throughout all brands?
Well I called MVP motorsports and the one guy that deals with the lexus and supras recommended the RPS Max PP and the Street disc. He stated that he has had complaints about the SPEC clutches and that a lot of people like the RPS. I then told him that I have read on the forums that a hand full of people do not trust the RPS because they are know to not hold up to what they state. He then said that it was because those people went with the street pp instead of the Max PP. I went ahead and ordered the RPS Max PP with the street disc, but they will not be shipping it till monday or tuesday. Should I change my order? Also he stated that if I had any problems with the clutch, just let him know and he will deal with RPS.
![Thumbs down](https://www.clublexus.com/forums/images/icons/icon13.gif)
RPS does not warrantee their clutch disks period. MANY people have had problems with the RPS Max Pressure Plate and full face ASCO relabeled "street disc." The clutch disc wears out prematurely and their clutches IMHO are overpriced junk.
If or when you do have clutch problems with the RPS, maybe MVP will take care of you better than HorsePowerfreaks did with me. (all HPF did was refer me to rps and i got screwed over in the end)
MVP said that RPS will only warranty authorized dealers. The guy told me that they have a 180 day warranty, better than nothing I guess. When I asked him about RPS being Asco parts, he said he was not sure and he's pretty sure RPS is their own company. From reading, it seems that every clutch kit has it's ups and downs. It also sucks that I have to purchase the bearings separate for the RPS kit. Well like I said, I have till monday to change my mind.
If you click the clubna-t link I posted, read the thread, and look at the pictures, you can CLEARLY see the "rps street disc" that you pay ~$150 is a relabled ASCO clutch disc ($80) with rubber inserts instead of springs. It is not their own clutch. I highly do not recommend RPS clutches, but it's your decision regarding what you purchase.
The clutch you ordered will work great. MVP knows their stuff and they will take care of you if you have any issues. RPS is highly recommended by many supra owners for good reason. IMHO just about every aftermarket clutch you'll find for your car will work and last long if you don't abuse it. Although, i wouldn't buy such an inexpensive cluth unless you plan to drive like a granny for 20k miles.
aight peace
aight peace
![Chicken](https://www.clublexus.com/forums/images/smilies/chicken.gif)
