Tuning options for na-t... lets discuss
Please, my car has made 570 to the wheel on pump/low boost, being an NA-T. Both motors are more than capable of producing 800 plus with the right precautions. Im not disputing the GTE is the way to be, but NA cars have quite a bit of potential.
As you can see, the NA's dont look so bad under there, providing you have the right parts. As for tuning measures, we die hard reccommend the AEM
Josh
Josh
If you don't want to spend the cash on an AEM, then Get the emanage ultimate. I know it has a bad rep, but IMO it works 10X better than the Map ecu, SACF or VPC plus it has timing control. It is also very simple to get it up and running safely. We have an automatic GE Supra with 880cc injectors @ 20psi running the ultimate. Once wired up all we did was input the stock injector size and the current injector size and little else. Idle quality is like stock and A/F ratios are all safe without adjustments. Fine tuning is also easy.
Josh
Josh
Sexy car btw
there will always be na-t guys that swear by them.
IMO GTE with parts you have > NA-T Oil squirters anyone?!
myself and plenty of other ppl have put down a ton of power on factory na internals dome shape or not they share the same forging process as gte internals and try to tell dave h that the factory na wont hold up to big numbers for quite some time its simply the fact that not many ppl have ever pushed them that far
Na guys are flying in!!
Oil squirters? You dont build too many engines eh? Typically on high HP applications, we as well as many other builders, will eliminate the oil squirters. They rob valuable oil pressure from where you need it most at high rpm's, the bearings.
Im into NA-T because it is different and a challenge. My SC is being shot for a feature in Modified Magazine this week because its an NA-T. The GTE is no joke, but people have seen it, done it, and there isnt a tremendous amount of development left. But hey, to each his own
ahhh thats right, remove the oil squirters. Wonder why
SP (edit) didn't remove mine when the motor was rebuilt maybe because its a street car i dunno....No i don't rebuild motors very often, but i am a certified mechanic with 3 ase's if that helps? here
NA-T's ROCK AND MAKE CRAZY POWER. All i hear is how many people make power with them yet its so different. They are awesome, crazy cool, and neato. lol im not gonna lose sleep over it. "But hey, to each his own "
Sorry SVT for the hijack
This is true but only in terms of drag only cars. Most people leave these in. There's almost no point in having a GTE block if you plan on eliminating the squirters in the first place. All my engines have Oil squirters in. Including my stroker setup.
Eloquent response Id be willing to bet my lil ole stock block NA car would show you its tail lights all day long This thread was about NA tuning options, no? just out of curiosity did you BUILD or BUY your car?
JM51526
Road Course and Auto-X
04-14-15 03:07 PM
KC95SC400
Performance & Maintenance
03-14-11 06:13 PM
