'99 SC300 Auto Tranny Fluid Capacity?
Hi:
Anyone know the automatic transmission fluid capacity on a '99 SC300?
Thanks in advance...jakuta
Originally posted by jakuta
Hi:
Hi:
For the SC400 the capacity is about 8 qts I think. To change the fluid, it only take 2 qts or 2 liters. take the drain plug out, replug when all oil is out. Refill from the top, do not over fill. Do it again after a few days of driving until the oil is red (clean) if you like.
The shop manual recommend to change every 15K miles I think.
For SC400 need to used Toyota Type IV transmission fluid, very expensive.
For SC300 just regular Dextron II trans. fluid. I don't know that you can use Type T-IV or not.
shroomysou
31
12-24-19 04:04 AM
