opinion on spec clutches?
anyone here on the board have any opinions on spec clutches? looking to pick up a stage 3+ spec clutch for my 1jz using my w58 tranny. my bro is using a stage 3 for his deuce and it grabs with stock pedal feel.
They are smooth get the 3+
Best NA-T clutch would be the Spec stage 3+ "superclamp" part# STS853F.
![](http://www.horsepowerfreaks.com/viewimagetext.asp?p=SPEC&f=Clutches_Import_Stage_3@&fo=products)
565 FT LBS for the stage 3+ "superclamp"
It has a full face sprung disc and holds almost as much torque as the stage 5 with a solid 6 puck disc.
![](http://www.horsepowerfreaks.com/viewimagetext.asp?p=SPEC&f=Clutches_Import_Stage_5&fo=products)
589 FT LBS for the stage 5
The superclamp version of the 3+ is not even listed on Spec's site but they do have them. It cost $100 more than the standard 3+ but when purchased directly from Spec you get a 15% discount.
Sleepyboi
Performance & Maintenance
06-08-12 07:24 AM
