what bov is this??
haha, its my car, and its not the bov......the flutter is the compressor surge on the turbo, also the external wastegate has ALOT to do with it, i do have a HKS SSQV but you cant even hear it over that wastegate....ask any single turbo 1j or 2j or any car for that matter with the bigger turbo, thats the sound it will make when blown off with medium to high boost.....(6-15)
first time i watched it i heard nothing that resembled a bov, but that was on ****ty speakers.
watched it just now in my room, and on the final let off i'm pretty sure it was your bov![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
just curious what insert you are running on the SSQV. i only seem to be able to find vids of the purple inserts. . .
ok then people which bov is this one then? http://youtube.com/watch?v=lMs8Eq1Nal0 ...i know it's swap 2jzgte but still anyone know the answer?
hahaha....ok.....ITS NOT A BOV!!!!!!!!!!!!!!!!!!!!! thats the wastegate...all big turbos with external wastegates sounds like that......ok.....i have a tial38mm wastegate...his is bigger but sounds the same.....the wastegate makes that single loud purge sound, like a ping.......the flutter is the compressor surge,its leftover air......its not a BOV making that sound
1UZFE/2JZGTE
can you answer what insert you have? lol
the purple is supposed to have a chirp and i never heard it.
my friend loves the sound like that, and i've been thinking it's just compressor surge, but theres cars that seem to have no blow off sound at all, and just straight compressor surge, and it's LOUD.
so i'm curious if you are running a gold insert?(sinc ei didn't hear chirp)
and yea. . .that's pretty much it
The Amuse Supra gets the same sound in the BM video. . .it's more like a suction chirp than the sound i'm use to hearing from the ssqv purple.
http://videos.streetfire.net/video/f...9900b27179.htm
another vid ofthe sound.....as you can clearly see from this vid, its not the HKS making that sound
yup, 60mm...warning doesn't come in the 52, or else i might have tried to get that ![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
the hold feature is the only way i know that if i stayed boosting after fuel cut, the boost jumped to ~20psi, lol.
car's sitting in a garage now until i can piece together all my single parts, don't want to blow the thing up.
you gotta get some more day vids of ur car
just destroying people on the road.
also, did you dynotune/street tune? and if dyno, numbers?
no tune yet....it willbe faster when tuned....i will get more. also what else do you need for the single setup??? i got some stuff leftover....well just some parts..
SAFC
HKS adjustable cam gears
1 bar w/g spring
ic piping and couplers
dump tube
SAFC
1 bar w/g spring
dump tube
