turbo vs swap
Old 12-13-06, 03:45 PM
boostedny
boostedny's Avatar
Thumbs down turbo vs swap
Ive been reasearching and debating for months what to do with my sc300. ..I was looking into a swap or the turbonetics kit..the kti would run me about 4000 not installed..he swap would either be a 1 or 2jz(Auto) , that where i need your opinion. I want the most for my money. My goal is to get about 500 rwhp out of my car. Would would be the best for my money?
Old 12-13-06, 03:53 PM
DriftNsc3
DriftNsc3's Avatar
It depens on what condtion your engine is in. if it has low milage and running strong then go for the kit. If your car is a automatic then the tranny will NOT support 500whp. I don't even think it will hold 400whp. The 5-speed is a little stronger and can hold 400whp on a strong low milage stock tranny. A 1jz swap will be a little cheaper then the 2jz-gte swap. I can get the 2jz-gte swap for between 5-6k but thats from a friend and one hell of a price from what I've been told. The kit will be cheaper but it all depends on what shape your engine/tranny is in. You can always upgrade your tranny or just swap trannies all together. IDK how much trannies are.
Old 12-13-06, 03:54 PM
MJHSC400
MJHSC400's Avatar
I don't know a whole lot --- but if you want to make that much dependably a 2JZGTE or a 1JZ would be a better bet-- since they're built with the proper ingternals and lower compression from the factory, plus have piston squirters..
That's a lot of power, and the auto needs a few things done to it to handle that much power... I think it can, but will need a shift kit ---
How often do you want to make that much power?? Just once on a dyno to post the chart, or everyday several times a day??? That will determine how much you'll need to spend on any of the motors-- I think a 1J is the cheapest bang for the buck-- but you don't have to use the turbonetics kit to boost your n/a motor, there are lots of guys out there with used parts letting them go for cheaper than you might think...
I'm sure others will chime in with better advice. I've been thinking about this for an SC400 too.... 1UZ's are expensive to wake up... A 1JZ on the other hand can be a monster with 2 grand....
Old 12-13-06, 05:08 PM
atekt
atekt's Avatar
Its up to you man. Both ways are good ways. If your GE motor is still strong, go for it. The internals are tough as ****. But you cant go wrong with the 1j. It was the best thing I could do for my car!
Old 12-13-06, 06:22 PM
Duckness
Duckness's Avatar
id go na-t and build the auto tranny to withhold the power since u want 500whp
Old 12-13-06, 07:18 PM
Psionic
Psionic's Avatar
If you just want 500hp, stick with na-t.
Old 12-13-06, 08:10 PM
MJHSC400
MJHSC400's Avatar
I think he wants 500 whp-- big difference-- A good $2000 gap there..
Old 12-14-06, 07:08 AM
boostedny
boostedny's Avatar
Thumbs down
thanks for the info..Im looking to have 2 boost settings, one at 7psi,and one at 14 thats if i do the turbo kit. I was loking into the atristo motor and the boostlogic built tranny..is the I can get the aristo motor and tranny for 2300 plus installation..but would there be alot fo extras i would need to by separately to complete the swap
Old 12-14-06, 07:47 AM
ConSynX
ConSynX's Avatar
can a 1j make 500whp w/ pump gas easily/reliably?
i was gonna recommend a na-t or 2jz swap for the extra displacement.
Old 12-14-06, 08:21 AM
plex
1UZFE/2JZGTE
plex's Avatar
I was in this same dilemma about a year ago. I personally would go with GTE's just based on the ease of tuning. If you do na-t just go with the aem from the beginning to make tuning easier.The aftermarket for the 2jzgte is plentiful with lots of choices and the aftermarket for the 1jzgte is growing fast too. Whatever choice you make just do it right and don't cut any corners.
Old 12-14-06, 04:49 PM
boostedny
boostedny's Avatar
Thumbs down
Im jsut looking for a solid reliable daily driver..that I can have a little fun with. Im not much into racing but Id love to have someting that has the power if needed. if I was to get either the 1jz or 2jz would it how much power would be possible to get out of it with on bolt ons? As of now I have a legalis R exhaust on my car hows the figure into the equation? And is there anyway I could figure out that 1/4 mile time id run with a certain amout of horsepower? sorry about all the questions
Old 12-14-06, 06:39 PM
atekt
atekt's Avatar
A 1j with bolt ons is an awesome car! So much power on tap...ALWAYS. A 2jzgte with bolt ons is a monster but also cost alot more. Are you going for 500 to the wheels or daily driving plus extra power? Cause there is quite the difference.
Old 12-14-06, 07:32 PM
boostedny
boostedny's Avatar
Thumbs down
I have a 98 sc300 if that makes the difference.....im loking for round about 500 wheel ..daily driven...jsut enough to put out a largewr amount of guys if the decide to race me.,..and for some reason many people do....what do you think
Old 12-14-06, 09:00 PM
Rising_Sun
Rising_Sun's Avatar
Well since you have the VVT-i motor. I'd recommend the 1J or 2J-GTE swap. The VVT-i rods are not that boost friendly.
Old 12-14-06, 10:57 PM
MJHSC400
MJHSC400's Avatar
Just get a Miata and swap an ls1/t56 in.... 11.3's or so stock.
Quick Reply: turbo vs swap
