Help! My sc300 drives rough and has white smoke that comes out on occasion
The car has embarrassing billowing white smoke coming out the exhaust again with a terrible smell followed by rough driving. I have a feeling the head gasket is blown. I wasted over 2,700 on this damn car, no more. Getting sold or junked. It's in excellent mechanical conditon after replacing all the key parts, clean body but what good is it with a sick motor.
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
Bummer, especially given what you've put into it and the excellent overall condition of the rest of the car.
Selling it is going to be a nightmare lowball. The $2,700 is sunk costs and you'll never get it back. That's why I'd be sorely tempted to just to put a 1jz into this and change your entire outlook on it.
Of course there's the fact that 2jz-ge engine are plentiful and sell @ ~$$500 to 900. Because of the number of 2jzgte swaps some damn nice engines are going for next to nothing.
Best Luck to you sorting this out.
If you are low on cash I would go to the autoparts store and get some bars leaks. It may fix your problem.
My HOndas headgasket was toast and bars leaks fixed the issue for me, I just put another bottle in every year or so, it has been running okay for over 20K miles with the bars leak
What is bars leaks? The car doesn't leak any oil. I will try it, anything is worth a try at this point.
bars leaks is a sealant that seals up coolant leaks and blown headgaskets. It doesnt always work but it often does, it is a good last resort.
http://www.barsproducts.com/
Look under radiator and cooling.
If you have a bown gasket wouldn't the car overheat? My car does not overheat, temp doesn't even so much as nudge. Can anyone here tell me what your symptoms were when you got your blown gasket? My car does not hold idle at first start unless the car is warmed up several mins, then drops to a really low rpm.
There a complaints that there is little to no market for these engines. You'll probably want to do some engine seals, belts and hoses before its installed because of how accessible everything it.
Be patient and learn all you can about any engine you're serious abouts' history, there should be a few around.
http://www.supraforums.com/forum/sho...ighlight=2jzge
A straight engine swap by a shop who knows Toyota's should be a one day deal. Your best sourse for a 2jz-ge would be to place a WTB ad on this forum and SupraForums.com
Update. It has been a couple of months and the car is running smooth with no more white smoke. I guess it wasn't a BHG. The only problem now which is minor is that it has to warmed up up for a few mins at first start of the day or the car will cut off due to a low idle. Once it's driven it holds idle and drives fine. Maybe it needs a new ecu?
Its still a blown headgasket. the car will run fine with a blown headgasket untill enough liquid seeps into your cylinders. the white smoke is steam the funky smell is gas/oil. and the rough idle is misfire becuase of the liquid in the cylinders. the car dies becuase of the liquid in the cylinders. you have ablown head gasket im 10000000% sure of it. the temperature gauge does not read hot becuase the sensor cannot get an accurate reading. do a leakdown test and you will see at least one cylinder has a leak. its the head gasket. replace it or replace the motor cuz you wont even get $2K for a car that doesnt run.
