Megasquirt!
Old 04-02-10, 01:42 PM
YeA 2jZ
YeA 2jZ's Avatar
Originally Posted by Carfreak70
Bump for an old thread! I am wondering if anyone (now-a-days) is running megasquirt. I have a buddy who is wanting to try it out on my car, but I want to see what all would be involved.
I will possibly be using it on my NA-T build there are a few s.fl members on here running with great results. If you want more info pm Shaodome hes the local guy that builds,installs, and tunes it down here.
Old 04-02-10, 08:36 PM
TLDriver
TLDriver's Avatar
from what I have read it can be made to work, I haven't done it yet and I am still building it. I have also read and learned that I will need to integrate some GM sensors for my build and some other modding to make it work. The GE is a little different then the GTE's because the crank wheel will have to be modded on both to make so the MS setup will work, by doing that you "should" be able to go coil on plug on a GE. Once I figure it out on my GE I will try to get a write up done.
Old 04-02-10, 10:09 PM
Carfreak70
Carfreak70's Avatar
why not just use mkiii cps?
Old 04-03-10, 10:46 AM
Dew23
Dew23's Avatar
PM Shaodome or browse the Florida section he has good luck with the megasquirt.
Tlaurin3
05-09-18 03:44 PM
empera
SC- 1st Gen (1992-2000)
05-20-10 12:29 PM
Drkgreensc
02-17-10 09:33 PM
scENFORCER
20
12-14-06 06:29 PM
CheryRd1JZ
05-19-06 03:14 PM
Quick Reply: Megasquirt!
