1jz motor mount question
Old 01-03-07 | 11:19 AM
matthatter's Avatar
matthatter
Default 1jz motor mount question
Ive installed a 1jz with 1jz brackets and 97 supra mounts in my 92 sc300. My problem is that there is not enough clearance for the motor to sit on the mounts. It appears to be less than an inch too short. I read that the 93.5-95 mounts are an inch and a half taller. Should I be trying to get the older style mount or could it be an issue with the wrong brackets? Any response would be appreciated.
thanks
Old 01-03-07 | 06:45 PM
got_trd's Avatar
got_trd
use the long brackets with short mounts and vice versa.......
Old 01-03-07 | 09:42 PM
matthatter's Avatar
matthatter
so are you saying that 97 brackets should get me where i need to be?
Old 10-12-07 | 10:00 AM
Rexn30's Avatar
Rexn30
Can't you use 98 supra TT mounts with stock mounting brackets?
Old 10-12-07 | 05:17 PM
sc250tt's Avatar
sc250tt
you need 1j mounts or 97 brackets
okula247
25
05-15-11 05:35 PM
nismo2trd
07-11-07 01:40 PM
dirtyhands
03-03-07 07:11 PM
supraglen
SC400 / 300 Classifieds
06-06-06 10:40 AM
jbiel
12-27-05 04:26 PM
Quick Reply: 1jz motor mount question
