code 17...
Hey guys Im getting a code 17, CMP No. 1....is that a circuit malfunction, what does CMP stand for? Also any possible solutions? BTW car is a 94 SC 300
secondly, you might want to do some diagnostic work and see if it's truly the sensor itself before you actually replace it - it could also be wiring... just to possibly save some money...
I believe on supra forums you can download the 95 TSRM which has the diagrams for both the 2JZ-GE and 2JZ-GTE, that will help you out alot.
And like Mitsuguy said most likely its not the sensor, and a wiring issue. If you download the manual you can actually test the resistance between both terminals on the sensor and it can give you a fair idea if the sensors are bad or good. The manuals will be alot of help
