motor mounts?
I don't know the part #, but the best place to get them is from Pembroke Pines lexus in Fla.--
I'm pretty sure they're the cheapest out there--
They can tell you the part # too---
I just bought all 3 mounts for an SC400 from them for less than $200
does anyone know if the 92 mounts are the long ones or the short ones cuz if i can't get the part number i'll use the mkiv ones but need to know which mounts are the same since i have both part numbers for the mkiv
i kinda need the mounts asap cuz my car is in the shop for a engine swap and all 4 of the mounts ripped apart. does anyone know if the 97+ supra mounts the long or the short ones?
I believe this thread has the info you need . https://www.clublexus.com/forums/sho...=engine+mounts
Different, yes, as in tougher design (encased in a protective metal jacket) and cheaper.
There is no difference in TT or NA that I know of because the shortblock's external features have no meaningful differences. The part number are the same.
I think some people get confused between the motor mounts and the sub-frame mounts. Those are completely different situations.
The 1997 toyota supra twin turbo mounts are a perfect fit for the SC300 cars. When I put my replacement 2jz-ge engine in my 1995 sc300, the 1997 toyota supra twin turbo engine mounts fit perfectly
. Another plus, is these toyota supra tt engine mounts are solid (sc300 using rubbery material that degrades) and they cost less than one single lexus sc300 engine mount
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
