2jz-gte swap into SC400
01-25-07, 07:09 PM
i know that 2jz-gte swaps are perfect drop in for the SC300 but is it the exact same for the SC400?
as far as lining up motor mounts etc
01-25-07, 08:47 PM
Theres a thread about it in the forced induction section. Do a search there (it is a big discussed topic). I believe you need to change the subframe, and the wiring is different. It is usually better just to start off with a 300.
01-26-07, 11:05 AM
i did a 1j in a sc400 .they all have the same subframe .if you do a search on 1j in sc400 you will get some results
01-26-07, 11:17 AM
so the 1jz-gte and 2jz-gte essential is almost identical as far as fitment and dimension wise?
so if the 1jz-gte fit no problem in the sc400, then that would mean the 2jz wouldn't be a problem either?
thanks
01-26-07, 11:23 AM
Former Sponsor
same subframe you may need the oil pans etc depending on what 2jzgte you get.
01-26-07, 11:37 AM
Quote:
Originally Posted by
tuninghaus
thanks
and they already said...
Gibenstein
sc250tt
if you do a search
I guess you just don't wanna huh?
You'd get more specific info that way, but...whatever.
01-26-07, 11:44 AM
mikeloc24
haha it's not that i'm lazy but if someone actually knew the answer it wouldnt take but one sentence like the previous member just stated.
i did look and searched but most came up as sc300 - 2jz-gte swap where i need a sc400 swap.
01-26-07, 12:43 PM
look up JamesN and 2jz-gte swap...he has a 2jz-gte swap in his SC400...
01-26-07, 12:50 PM
My bad, I thought I read on somewhere that the 400 subframe was different. I still believe the wiring is different though lol.
01-26-07, 01:59 PM
Keeper of the light
tuninghaus
ok, but then why didn't you use the engine forum?
breadsc400
SC400 / 300 Classifieds
02-25-13 06:07 AM
cristian06
SC- 1st Gen (1992-2000)
15
11-10-10 03:31 PM
tuninghaus
Performance & Maintenance
07-06-08 10:03 AM
BoostenSC4
Florida Lexus Club
10-22-07 08:48 PM
1j ,
2jzgte ,
easier ,
fit ,
hard ,
install ,
lexus ,
oil ,
sc300 ,
sc400 ,
smell ,
subframe ,
swap ,
swaps ,
wiring
