jzz30 body plugs,IJ1&2,IK1&2
I just wanted to say hello to everyone. I am new to this forum and was wondering if any one would help me. I am trying to find out the wire colors/what each do for these 4 plugs. IJ1, IJ2, IK1 & IK2. Can any one help with the pinout of these connectors? Much appreciated.
http://www.trackdaymedia.com/~manny/Tech%20&%20Diag/
http://www.trackdaymedia.com/~manny/...0__pinouts.pdf
those are the ecu plugs let me search some more
im having the same issues... anyone resolve this ever??? most of the wires i can trace using my original harness, but many of the sc wires are unused and the sc harness doesnt even have many of the 1jz wires.
Kevin
Kevin
your best bet is to go to alldatadiy.com purchase a year subscription to their online repair manual for the year sc you have, it has the complete factory wiring diagram it is 14 bucks best deal i've seen its not as complete as the factory manual but as far as i know the wiring diagram is pretty much a photocopy out of the factory manual its got 90% of the electrical stuff in the car along with other specific car stuff.
p.s. those links posted by biggu have good info for the 1jz stuff i used those plus the alldata info to complete my swap, oh and i have a soarer ecm or wiring, everything is out of a chaser and nothing matched up and i was able to get it running properly it took awhile with a volt meter tracing wires but with some searching and some general auto knowledge it can be done
PM me what information you need and I can get it for you.
IJ1
Red/yellow (ELS)
Yellow/Green - (Engine Light)
Small Black/White (Neutral Start Switch )
small black/white - (Starter)
Red (Fuel)
Green (Fuel)
red/green -Fuel
Black/Orange (Switched power, ignition)
Black/Red (Fuel Main)
IJ2
Pink (Speed)
Black/Yellow (12v switch, alt to charge batt)
Yellow (speed sensor)
Red ( Primary Throttle ) TPS
Black/Orange (switched power, ignition)
IK1
Yellow/Black (Oil pressure gauge)
Red/Black (Reverse lights)
Yellow/Green (Water Temp Gauge)
Black (Tach)
Blue/yellow -(engine light)
Red/blue IJ1 (speed sensor)
Blue -(at switch)
IK2
Brown (Ground for Fuel Pump)
Black (NSW)
Black/blue (NSW)
Brown (ground for cluster)
There are two plugs on Driver side near Junction Block #2, a 3 wire plug and 7 wire plug
2 big power plugs near battery
3 wire plug EB2
• Black – yellow from old alternator plug and black from EB1
• White – white from old alternator plug
• Black/Red – Black/Red from C1 plug and Black/Red from EB1
7 wire plug EB1
• Blue –Blue from old AC connector
• White – White of C1 plug
• Black/Red – Black/Red of C1 plug and Black/Red of EB2
• Black – Black of EB2 and Yellow of old alt plug
• Black/Orange – Black/Orange of C1 plug
• Black/Yellow – Black/Yellow of C1 plug
Red/yellow (ELS)
Red (Fuel)
Green (Fuel)
red/green -Fuel
IJ2
Pink (Speed)
IK1
Black (Tach)
Blue -(at switch)
IK2
Black (NSW)
Black/blue (NSW)
3 wire plug EB2
7 wire plug EB1
Golden95SC
Performance & Maintenance
13
10-04-24 07:57 PM
1uzforme
05-29-12 12:07 AM
