Changing head gasket for sc300
I am sorry to hear about that. It is not an easy task which is why I hear shops charge up to $2000 for the job.
I had never worked on this engine before so it took me awhile to learn how everything went together. The Toyota engineers are some tricky bastards that like to locate bolts where you can't see or reach them.
I think it took me 2-3 days to get down to the head gasket making sure I knew what everything was and where it went.
You will need to remove almost all of the engine except the lower half of the block.
Things that will have to come out:
intake system
throttle body
intake manifolds (all 3 parts)
engine cover
cam covers
cooling fan
engine belts
distributor
spark plug wires
a lot of vacuum hoses (mark them or you will forget where they go... I forgot and it took me another few days just to work out where they plugged in)
cam gears
cam shafts
EGR valves and piping
Finally the head
There are alot of smaller things attached here and there that will need to be removed as well.
It was a lot of work, but I am glad I did it. Now I know how to get into the engine if I ever need to which will save me more money down the road. My girlfriend came in and saw hundreds of car parts scattered around the garage and didn't think it would ever run again.
I have a factory service manual in PDF format that you can have if you want it. You will definitely need to reference it.
intake system
throttle body
engine cover
cam covers
cooling fan
engine belts
distributor
spark plug wires
cam gears
cam shafts
Finally the head
factory head bolts are torqued to yeild. so, either get new bolts or arp studs.
setting timing is easy, follow the fsm. remember to take off hte distributor cap to make sure the rotor is pointed to plug wire #1
you dont really need to change any other gaskets unless you have leaks.
head gasket can be dont with motor in the car.
changing the headgasket on a 2jzge is simple. you'll spend most of the time just cleaning parts before you reinstall them.
Don't forget to resurface the block. You want to get the block and head as flat as possible. Or else your going to blow the head in a sort period. As opposed to doing it right. While your down there. Do a complete engine rebuild/overhaul. Why waste time in acouple mo/yr's in the future to take the head off agian... ?! Since your down there already. Why not go the whole way and get the block worked on. Might save you acouple hr's/nights to do it all over agian.
can i get that PDF You where talking about please. i also replaced my head gasket and set timing and now she aint running right. i really could use the referance and trouble shooting if you have it?
Thanks.
Thanks.
intake system
throttle body
engine cover
cam covers
cooling fan
engine belts
distributor
spark plug wires
cam gears
cam shafts
Finally the head
intake system
throttle body
engine cover
cam covers
cooling fan
engine belts
distributor
spark plug wires
cam gears
cam shafts
Finally the head
I have a factory service manual in PDF format that you can have if you want it. You will definitely need to reference it.[/QUOTE]
Is there anyway I could get that PDF?
that was from 2007. here is the online 95 supra repair manual which is the online version of the PDF.
I use most all the engine and some of the suspension is the same for the SC.
http://www.supracentral.com/foundation/mkiv-tsrm/
you want the "engine - mechanical" section and it has 2jzgte and 2jzge, obviously you should follow the 2jzge one that the sc300 has.
