OBDII + Turbo?
Chicago Lexus Club Moderator
Chris
No. It won't matter if you're obd I or obd II. Try to get an OBD II SC300 so you can have it tuned better with the map-ecu. OBD I (karmen vortex cars) do not work well with map-ecu. The advantage of obd II SC300 with map-ecu is your car can be much finer tuned and have more control throughout the rpm range. If you have a 5-speed manual transmission sc300, just get a cheaper stand-alone ecu solution like the Haltech E6X. That way you won't have to fight your oem Toyota ECU.
edit:
Map ecu and map ecu2 can be found here
http://www.mapecu.co.nz/
I want to thank everyone for answering my questions perfectly.
Keywords incase someone in the future wants to search for the same question: OBD OBD2 OBDII II Boost Sc300 Turbo
