I dare you to figure this one out.........
#78
This is a solid fix for the problem of the leaking valve. The variable power assist doesn't do a thing for me. Long as it works, doesn't leak, and doesn't cost me more than $3.30 to fix I'm fine with it.
I have full power assist, no leaks, and full pockets.
PS- just incase someone thinks they can plug the valve openings and go..... it won't work. I tried it.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
The fluid blows the caps right off even when zip tied. Here are the two outputs with rubber caps. This does NOT work.
I don't think boost is very good for this valve, so I would disable it either way.
If your switch is broken (leaking fluid) then yeah, It probably won't work as OLT suggested.
His is definitely a more permanent way to go about it.
#81
My PS regulator bypass fix explanation video: http://www.youtube.com/watch?v=dMwsaX2lgWA
Jonny
#83
Very good post thanks for the info, This will possibly save me two issues on Sheila...
My salute to you on this very informative post.
PS leak fix and broken or bad vac lines.
Just to clarify this mod will only increase power assist at high RPM so if I am driving 70 MPH the steering is super light meaning my muscles are too strong.
other than that at idle is normal?
#84
attzor
Performance & Maintenance
10-11-12 09:56 AM
