Report: Replaced Transmission mount on 13 year old car
Old 02-06-07, 07:06 AM
ChronoJ1
ChronoJ1's Avatar
Default Report: Replaced Transmission mount on 13 year old car
Problem: Whining, vibrating, clunking transmission
Solution: Replacing your transmission mount
Where: Lexus Dealer
Cost: 190 dollars including parts and labor
Result:
- EXTREMELY Smooth gear engagement. Almost feels like my car has a CVT.
- Shifts at higher RPM
- No more rattling/whining noise at idle
- No noise in extremely cold weather
- No more play/clunking in the gear when you step on the gas then let go and then step on the gas again.
Old 02-06-07, 07:12 AM
Jewcano
No Sir, I Don't Like It
Jewcano's Avatar
Did your shifter rattle before you replaced the mounts?
Old 02-06-07, 07:18 AM
ChronoJ1
ChronoJ1's Avatar
The shifter itself, no. The vibration came from under the car initially, then when it got worse, the differential box in the rear started making noise.
Old 02-06-07, 07:34 AM
sourcemine
sourcemine's Avatar
Nice, I need to do mine soon too.. its on my list..
Old 02-06-07, 07:39 AM
Jewcano
Jewcano's Avatar
I see, o well thanks anyway.
Old 02-06-07, 08:12 AM
cal9126
cal9126's Avatar
I really need to get all the mounts on my car changed out.....
Old 02-07-07, 08:19 PM
NYCsc300
NYCsc300's Avatar
my shifter rattled when my brakes got low.. my driver side brake capiler was lower then the pass and thread was broke(forced blot in and worked) changed the brake pads rattled stop
Old 02-08-07, 09:12 AM
Jewcano
Jewcano's Avatar
The thing is mine rattles regardless of if i'm breaking or not. It rattles the most at high speeds actually.
Old 02-08-07, 10:27 AM
Psionic
Psionic's Avatar
The bearing on the shifter is out.
Old 02-08-07, 11:30 AM
LexusFiend
LexusFiend's Avatar
Wow! they charged you 190 for a tranny mountchange? i did mine in 20 minutes, the hardest part was jacking up the car and the part cost me 50 bucks ... definately worthwhile
Old 02-08-07, 11:39 AM
ChronoJ1
ChronoJ1's Avatar
Haha, i know... it could've save some money if I did it myself.
But...
- No lift
- No garage
- Sub zero weather
- Snow
- Lexus offered a loaner RX350.
So, all things considered, i am happy.
Old 02-08-07, 01:00 PM
Jewcano
Jewcano's Avatar
Where can i come across this shifter bearing? Also how much they run for, and how hard is it to replace?
Old 02-08-07, 02:14 PM
97-SC300
97-SC300's Avatar
nice, it's a fairly simple thing to do if you want to save on labor!
Old 02-08-07, 06:36 PM
vince1128
vince1128's Avatar
how much is just the part?
Old 02-08-07, 07:51 PM
MJHSC400
MJHSC400's Avatar
$45-- Lexus Pembroke Pines-- 20 minutes of work--
Quick Reply: Report: Replaced Transmission mount on 13 year old car
