My 1JZ swap
Old 03-22-07, 10:43 AM
  #46
sc250tt
sc250tt's Avatar
i did not touch the computer harness i extended the bodyplugs only .i did not want to extend the ecu wires and ended up having problems there .if i were you i'll leave those wires alone
Old 03-22-07, 11:08 AM
  #47
plex
1UZFE/2JZGTE
plex's Avatar
Here's the solution to extending ecu wires.
http://autosportwiring.com/toyota.htm
I plan on getting one of these very soon will definately give me more space to work with. I hate going under that carpet.
Old 03-22-07, 03:34 PM
  #48
Psionic
Psionic's Avatar
I thought of that, but I decided to extend the part by the engine so that the rubber boot would attach to the car. I already started snipping wires there, so I will continue.
I guess I need to trace where the larger wires go so that I will extend the right ones.
Old 03-22-07, 03:45 PM
  #49
sc250tt
sc250tt's Avatar
all u had to do was undo the tape fron the rubber and pulled it towards where it bolts in ,but whatever way make you happy jus be careful with that route
Old 03-22-07, 07:35 PM
  #50
Psionic
Psionic's Avatar
Ok, I am extending at section "A", but are you saying to extend at section "B"? I am only 6 or 7 wires into it and it is easily repairable, but I dont want to get into a mess.
Old 03-23-07, 12:22 PM
  #51
sc250tt
sc250tt's Avatar
yea jus extend the B part of the harness it will save you alot of trouble in the longrun (less issues to troubleshoot when time to start her up) jus undo the tape around the rubber booth (might have to make a little slice on it) and slide it to the location where u want it
Old 03-23-07, 01:39 PM
  #52
yelloa3gti
yelloa3gti's Avatar
Ill be doing my harness extension sat am.
Old 03-23-07, 02:05 PM
  #53
ManicSC300
ManicSC300's Avatar
I've done 3 swaps so far in the last year. Trust me. It fits.
Old 03-23-07, 02:44 PM
  #54
ManicSC300
ManicSC300's Avatar
As far as throttle cable goes. Get a 92-96 4 cylinder Camry throttle cable, its fits. The MKIV doesn't without modification to the throttle cable holder, or use of a high tech zip tie.
Old 03-23-07, 03:18 PM
  #55
Deceptik1
Deceptik1's Avatar
That's the exact point I extended my harness as I was told you only need to do the kick panel plugs and not the ecu plugs.
Old 03-23-07, 04:27 PM
  #56
Psionic
Psionic's Avatar
Thanks guys! I definitely owe you guy a round of beers next time I see you.
The harness is fixed and I am about to extend it the right way now.
Old 03-24-07, 10:39 AM
  #57
sc250tt
sc250tt's Avatar
nice is it a direct bolt in?
Old 03-27-07, 09:26 AM
  #58
yelloa3gti
yelloa3gti's Avatar
The 1JZ GTE sitting on the garage when i got home
Old motor out
harness extension
new one going in
SHE IS ALIVE.. started the swap sat am and had it running sunday afternoon. Started and ran awesome on first crank. Still have a little more to do before Im driving it
Old 03-27-07, 09:55 AM
  #59
plex
1UZFE/2JZGTE
plex's Avatar
Congrats bro time for me you and PJ to go cruising lol.......
Old 03-27-07, 09:57 AM
  #60
E-Z ES300
E-Z ES300's Avatar
Sick Sick Sick Sick Sick!!!!!!!!!!!! Congrats And Goodluck!!!
Quick Reply: My 1JZ swap
