1jz swap giving me the blues!!
Old 02-08-07, 10:59 AM
Answer300
Answer300's Avatar
Default 1jz swap giving me the blues!!
okay 1jz heads, i have a problem with my swap im trying to figure out. i recently bought a swap and after i studied it; come to find out its a jza70 swap. now; the harness was cut going to the ignitor so i got rid of it and picked up a "supposed to be" Soarer harness. after looking into that matter i discovered its a Chaser harness JZX100. my harness will only allow 2 plugs to go in the ecu and the others may be body connector plugs some where on the car. the reason why i dont want to sell this swap is because its a low miles on it (77,458km) is there a way to make this work or am i SOL!!!
Old 02-08-07, 11:08 AM
Sc400Red95
Sc400Red95's Avatar
IF that was the problem. Why not re-wire the harness in question to fit your Sc's body harness... Don't give up... If anything try and find one from a Supra 93+ That 2j harness will work... You can even use the 2j harness on the 1j itself. But you will have to run a 2j ECU. Doesn't have to be a manual one. The automatic will work. In your case. I would just rewire that bad boy and your done. You can most likly just color match the wires... If not look for a wiring diagram of the harnesses.
Old 02-08-07, 11:33 AM
Answer300
Answer300's Avatar
so basically once i pull the 2j-na harness out, just mate it to the 1jz. and i also discovered that the two plugs that go into the 3 and 4 ports of the ecu are the same configuration as on a toyota camry! i had a friend at the shop point that out to me. pretty funky i think! but hell, the only reason why im sweating this is because i dont want to sweat this summer in texas! these are mostly AC plugs and pinouts.
sc250tt
sc250tt's Avatar
the motors are prettymuch identical ,if you get the soarer harness it would make much easier for you .the sc 300 harness wont work at all .or maby try getting the chaser ecu
Old 02-08-07, 11:39 AM
Answer300
Answer300's Avatar
i got the chaser ecu also. the funny thing is everything else plugs in on the motor minus where the engine harness doesnt have a plug for the back of the altenator.
my car is a original 5 speed if this helps anyone.
Old 02-08-07, 11:49 AM
Sc400Red95
Sc400Red95's Avatar
Han- Are you saying there is no connector for the Alternator but there is wiring. Or is there no wiring. If there is wiring. Just use your Old harness and swap connectors. IF you use a Supra TT harness your going to have alot of connectors unpluged. Thats for the Twin turbo set up.
Old 02-08-07, 11:53 AM
Answer300
Answer300's Avatar
yea there's no wiring going coming from the harness with a plug on the end like my sc harness has.
that TT supra harness has my attention!! hmmm....
Old 02-08-07, 11:56 AM
Rising_Sun
Rising_Sun's Avatar
I have had this problem twice before. The chaser ECU plugs are the same shape as the Soarer. So its easy to get the 2 confused. The JDM MKIV TT Harness is similar but the body plugs are different. My solution was to sell the CHASER wire harness and ECU. THen purchase the right JZZ30 Soarer wire harness and ECU. It took me less than 2 hours to wire up the motor with the soarer harness.
Old 02-08-07, 12:11 PM
Answer300
Answer300's Avatar
are true soarer harnesses easy to come by these days? id basically have to find someone with a blown motor and convince them to sell it to me..
are there any shops in the US that periodically has them in stock!
i just wanna ride mann!!!
Old 02-08-07, 12:41 PM
Rising_Sun
Rising_Sun's Avatar
They're not easy to come by. Just keep checking Supraforums, Ebay, Jhot and Jarco. Good Luck!
Old 02-08-07, 01:34 PM
Sc400Red95
Sc400Red95's Avatar
That would be the easiest. To get a Soarer harness (of course). I am sure it's there the alternator harness. Maybe it's been riped out..i wouldn't know. How about some pictures of the harness. That might help. Also if it's totally not there just add it in... OR you can pay someone to do it. Give Driftmotion.com a try. In so cali they are considered on of the best with the 1j's. Really clean swaps. They did my Supra 1j and now they are doing my 2j. So i trust them alot with all the crap i am doing to my Lead Sled.
Old 02-08-07, 01:39 PM
Answer300
Answer300's Avatar
that sounds like a plan buddy! thanks for the help guys!! feel free to chime in with suggestions!
Old 02-08-07, 02:08 PM
roo
roo's Avatar
I'm going through the same with my engine/harness....found a soarer harness but now I need a new harness for my HKS FCON >_<
If you can't find a soarer harness, let me know, the guy I got mine from might have more...
Old 02-08-07, 02:20 PM
Answer300
Answer300's Avatar
how much will it be. im down for a good price!
Old 02-08-07, 03:17 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
lack of using the engine forum giving me the blues
Please use engine forum
Quick Reply: 1jz swap giving me the blues!!
