lightweight battery
Old 02-09-07, 05:18 PM
over40driv
over40driv's Avatar
Cool lightweight battery
Im pretty sure my battery is going bad, going to loadtest it tommorow afternoon. If its bad I hear a lot of people talk about switching to a lightweight battery to lose frontend weight, want to know what is the lightest, still with enough amps to run the system and not shorten alt. life.
Old 02-12-07, 05:19 PM
over40driv
over40driv's Avatar
OK so the battery was ran down, but no dead cells or shorted plates. Charged the battery and checked the system for a drain, and there was one. Opened the trunk and the c.d. changer was buzzing and whirring, so I pushed the eject button and it stopped, and the drain was gone. Wanting to know if anyone knows whats going on with the c.d. changer. Also the radio power button was off, but when I turned it on it said c.d. err.
Old 02-12-07, 05:33 PM
Lexmex
Super Moderator
Lexmex's Avatar
Here you go, http://www.brailleauto.com/
Lightweight and high cranking amps.
Old 02-12-07, 05:49 PM
CleanCL
CleanCL's Avatar
http://www.odysseybatteries.com/ > *
Old 02-12-07, 05:54 PM
over40driv
over40driv's Avatar
11.5 pounds and 225.00 dollars, think ill take a look at an optima.
Old 02-12-07, 06:01 PM
tavarish
tavarish's Avatar
take a look at odyssey batteries, theyre awesome. 15 pounds, and i believe can be found for around 120
Old 02-12-07, 06:13 PM
over40driv
over40driv's Avatar
Looks to me that the size battery to do the job is 37 lbs..Would need to weight mine.
Old 02-12-07, 07:22 PM
Blizzy
Blizzy's Avatar
My battery is by no means in perfect shape. Thread piqued my interest a bit.
What size battery would do the job? What kind of current and power is the stock set-up running? What would be required from another battery?
Old 02-13-07, 05:08 PM
over40driv
over40driv's Avatar
850 cca , 90- 100 amps, also the odyssey battery did not have online pricing, but if my battery were bad id be calling them.
Old 02-13-07, 07:07 PM
Lucky SC
Lucky SC's Avatar
does anyone else find the braille language below their logo a bit strange and funny like me
thats horrible, i can't believe they thought that was a good idea lol
Old 02-13-07, 07:10 PM
Willicuddy
Willicuddy's Avatar
If you want to lose front-end weight, why not just relocate the battery to the trunk. Also, the added weight in the back will give you a little better traction (nothing noticeable i bet though).
Old 02-13-07, 07:24 PM
over40driv
over40driv's Avatar
Thats an idea, but with the increased battery cable diameter the weight would be more, and traction is really not the prob.
Old 02-14-07, 08:12 PM
Blizzy
Blizzy's Avatar
that non-carbon, 11lb battery for $179 from Braille seems like a pretty sick deal. 11lbs is really light, and 900+ cranking amps is huge. Being in an Ariel Atom makes it that much cooler.
Obviously you would need to creatively throw together a lightweight mount, but would you need new battery terminals with this type of battery?
(hilarious that they spell out dots in actual braille...should have had a seeing-eye walking stick spelling braille auto in the beach)
TLPLEXUS
HS 250h Model (2010-2012)
10-13-18 03:44 PM
drseth
SC- 1st Gen (1992-2000)
08-07-18 11:54 AM
Oro
08-04-15 08:15 PM
Sylexus
06-02-14 12:14 PM
Quick Reply: lightweight battery
