How many whp can a 98+ sc400 transmission hold
Before you all yell Search, i have, and came up with nothing. In the 98+ models lexus dropped the A341E transmission and put in a A650E transmission. what kind of power can the A650E hold? thanks in advance.
Shift kit will increase whatever the stock # is-- Less clutch slippage b/t gears= less heat= more power handling.
I know the previous A34#E in the 97 and older is similar to the same trans that comes in Sequoiah's and Tundra's 4.7-- very tough trans. -- Also came behind the Supra TT MKIV--
I wouldn't doubt 400+ on stock valve body-- moderately driven ie: not raced. A trans cooler would be a smart upgrayedd to add too...
