Just Changed Clutch And Now It Wont Start
I changed the clutch on my brothers 1992 SC300. I put everything back together and double checked the two sensors on the transmission to make sure they are tightly connected. I never disconnected any wires on the starter when I dropped the transmission. The battery cables where off the entire time. The starter will not click or even humm. I dont know what to do?
Moving SC Threads
Ground wire: underneath - l.s. frame rail to the bellhousing
engine bay - firewall to rear of cylinder head
Maybe 1 or both is not connected.
If it still won't crank, try jumping the clutch inhibit switch w/ a paperclip.
The switch is mounted under dash on the clutch pedal bracket. The switch
maybe stuck w/ all the pedal pumping....you did rebleed the system?
sparkyguy
Performance & Maintenance
07-04-17 12:57 PM
is3t
Performance
02-15-13 05:53 PM
