Technical data needed - Please post full ground points and wiring schematic for SC400
So I've searched and I've searched and the very closest I've found is a single comment by one user *within* an only partially related topic thread that mentions but two of the who knows how many grounding points on the early model SC400 electrical system. (specifically they mention the chassis to block point on the drivers side)
Can some one please post full ground points and wiring schematic for SC400.
I ask because I have to go check these points by what seems like an endless string of replies from O.L.T. to other members who's clocks are resetting themselves of who's engine has trouble starting / turning over even though their batteries are brand new, their battery cables are sparkling clean and their alternators have checked out as A-Ok. (just as mine all have).
Any help would be EXTREMELY appreciated!
Keeper of the light
You're spinning your wheels looking for *all* the ground points because they are too small to have an effect on the main system. Only the main grounds affect the system in a dramatic way. (block, chassis, battery)
There are over 12 grounds to frame in the dash alone, are you planning on removing your dash to check all of those? Of course not. They ground to the tube dash frame, guess where the dash frame grounds to......
Ok, so main grounds are all you need to focus on first. I'm fine with that.
That said and known, where are they located and is there a schematic for them available that can be shown here by chance?
Also, would the issue with my car being so hard to start have any correlation with the fact that my clock is constantly resetting it's self to 1:00 and I lose my tripometer numbers? Being all electrical I'd have to assume so in at least some way. Additionally what is the procedure for testing the starter on a 1993 SC400? Can it be even be checked (let alone fixed or replaced) without spending 800 dollars in engine tear down labor time?
Input?
I'd like to stay mostly on topic about the NEGATIVE GROUND POINTS / ELECTRICAL SCHEMATICS for the most part - but any input related to the starter in ways that might also pertain to that main topic is good info as well.
Input?
The first one goes from the battery to the chassis. Its probably the easiest one to find. Trace the thick black wire from your negative terminal down and you'll see that it ends up on the chassis. There's you're first ground.
Can't help you with the other two because I can't remember where I found them when I pulled my motor.
