New 95 SC400 Owner - Need Perf. Mods
make sure you find a mandrel bending exhaust shop if you are willing to pay the extra money and are serious about the performance from an exhaust without inherent restrictions at each bend. they are not easy to locate and you may have to do some driving to get it done right, but it is probably worth it given the research you have already invested into designing the proper exhaust.
Zombie Slayer
It most certainly makes a difference! Both N/A and turbo will benefit from mandrel bent tubing. Anything to reduce the turbulence and improve scavenging in the exhaust is an improvement.
If you simply want a certain sound or some bling via a stainless steel exhaust, clearly the above is not important. But, for anyone trying to get maximum performance from an exhaust, mandrel bending must not be undervalued.
I just think it is waste of money to get mandrel bent piping made on an N/A car. Cause the power gains would like be a clutch fan to e-fan mod, or removing AC mod, or putting on lightweigh pulleys.
Forced induction is another story though, you'll want as little back pressure as possible
just my 02cents
Zombie Slayer
The right size piping makes a difference. I've learned on other boards and forums Mandrel bent piping is for maximum performance. However it costs alot more to get exhaust pipes made mandrel bent than crush bent.
just my 02cents
just my 02cents
Anyone in Phx done a BFI on a SC that I can check out for reference? I would greatly appreciate someone to show me firsthand.
Thanks!
Thanks!
The BFI is really easy, just print off the planet soarer BFI3 instructions, sans the fiberglass part, drill the three 2" holes in the front of the airbox, cut out of an ABS top and side out of a 2'x3' sheet of ABS and your done. 2 hours if you have interuptions.
SCraper400
Performance & Maintenance
09-01-05 10:04 AM
