Check engine lights comes on and off
Old 02-28-07, 03:30 PM
taeng
taeng's Avatar
Default Check engine lights comes on and off
My check engine light is weird. At times it will come on and stay one for a couple of minutes and then go away. Then Sometimes it comes on for like 5 seconds and goes away. Has anyone ever had this problem?
Old 02-28-07, 03:49 PM
sc250tt
sc250tt's Avatar
my sc300 does the same thing sometimes it will come on for a whole day and then comes off .im thinking its the o2 sensor because its the original one in the car .it could be the egr too .im not to sure .run a diagnostic via the port in the engine bay and see what u came up with
Old 02-28-07, 04:55 PM
5spdSC300
5spdSC300's Avatar
Try pulling the engine codes. Even though the light disappears, some codes stay stored in the ecu. At least you will know whats tripping the cel.
Old 03-01-07, 06:43 AM
taeng
taeng's Avatar
Ok thanks for the replys I will be checking them out this weekend
Old 03-01-07, 09:36 PM
RLB
RLB's Avatar
pulling engine codes will probably tell you whats the problem might be, but the most common check engine light is the O2 sensor. If you didnt replace it in a while it is most likely the case.
Old 03-02-07, 07:49 AM
babyduke
babyduke's Avatar
I know little about cars. What does "pulling the engine code" mean?
tsl95
08-29-22 09:48 AM
JuztinCred
07-04-13 06:08 AM
clevercat
RX - 1st Gen (1999-2003)
07-07-09 06:39 AM
Niko1981
03-07-08 07:07 PM
DroppedGS
03-16-04 12:43 PM
Quick Reply: Check engine lights comes on and off
