auto to manual swap???
does anyone know of a write up in what parts are needed to do a auto to manual swap in a 94 sc300? and what parts are compatable such as clutch pedals and stuff like that.. because i'm definatly not gunna find a manual sc300 in a junk yard around here. this question goes for both 2jz-ge and 1jz.. becuase i'm tied between the two.
Zombie Slayer
No. No such write up. No one here would EVER dream of doing anything like that.
If they did ever have any CRAZY idea like that, they may have talked about it already and SEARCH might find that information. But since no one here has switched from auto to manual then searching would be pointless.
well im in the process for the complete auto to manual swap. im buying a 1jz and r154 from a JDM soarer swap for $2300 shipped. by the way ill be selling the 1jz since im going with the 2jz instead. if interested please send PMs. anyway im buying a w58 clutch assembly set. the dealers want on a average of $600 and change. but the guys at R & J's are giveing me a better deal. and once all of the other parts come in my friend at a shop will do the complete swap from auto to manual for $600-$650. i think youll need a mk3 r154's front half of the driveshaft and maybe a crossmember from a soarer. ill take pics from beginning to the end of the process.
Chicago Lexus Club Moderator
well im in the process for the complete auto to manual swap. im buying a 1jz and r154 from a JDM soarer swap for $2300 shipped. by the way ill be selling the 1jz since im going with the 2jz instead. if interested please send PMs. anyway im buying a w58 clutch assembly set. the dealers want on a average of $600 and change. but the guys at R & J's are giveing me a better deal. and once all of the other parts come in my friend at a shop will do the complete swap from auto to manual for $600-$650. i think youll need a mk3 r154's front half of the driveshaft and maybe a crossmember from a soarer. ill take pics from beginning to the end of the process.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
My swap is going good. It's simmilar to Supra auto to manual swap but little easier.
Chris
Parts you need for a 5spd conversion:
5speed Tranny (with 5spd mount)
M/T ECU
5speed Driveshafts
5speed Flywheel
Clutch kit
Clutch Master and Slave Cylinder w/ hardlines
Clutch pedal assembly
5speed shift boot and ****
5 spd Brake Pedal
Am I missing anything here?
-Allen
M/T ECU
5speed Driveshafts
5speed Flywheel
Clutch kit
5 spd Brake Pedal
-Allen
M/T ECU
5speed Driveshafts
5speed Flywheel
Clutch kit
5 spd Brake Pedal
-Allen
M/T ECU
5speed Driveshafts
5speed Flywheel
Clutch kit
5 spd Brake Pedal
-Allen
