Air/fuel Ration Install????
On a side note: Not sure why you're installing an air/fuel ratio gauge- those things are pretty much useless. If you want something useful, spend a couple hundred bucks and get a wideband o2.
-Allen
I cant hear you.
But I think you said you wanted a air fuel ratio gauge working, you connect a total of three wires. Red, Black, and X. With X you splice into your 02 sensor located on your midpipe or headers.
Keep in mind that different widebands/narrowbands are differently colored. It would help if you told us what kind of wideband you installed.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Once again thanks to all at CL for any help!
O.
i had the autometer digital A/F gauge on N02 gsr civic and it was useless it changed to quick for to tell if you where lean or rich when you needed to know. but anyways you tap into o2 sensor circuit
