need help wiring up 12v to fuel pump(sc400)
hello..i've install an brand new oem fuel pump and i'm thinking its not pumping enough fuel to the motor.correct me if i'm wrong? if i wired an constantly 12v w/switch its will pump better flow fuel?
if so where do i tap my wiring into?starter relay?
much help would be appricated.
much help would be appricated.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
If you get into an accident and have it wired the way you suggest, the pump will be constantly running and willl create a fire hazard.
why do you want to run 12v all the time ? Why not just get a high flowing volume pump. I.e. Supra TT. That thing flows 280L. If you need more than that APEX/HKS/Aeromotive/etc... make em flow about 380lph. If you need more than that My Aeromotive 1000hp+ fuel system. IF you need MORE than that they make a 2000+hp fuel system.
kuyayan
02-06-11 09:25 AM
