Warm Start Stalling on SC400...Please Help
To begin with, I have searched and nothing really matches my problem except having a dirty TB. I thoroughly cleaned the TB and also cleaned the AIC with no luck. On cold starts, it cranks right up every time. However, if the car is driven up to temp and sits for anywhere between 10 minutes to 3 hours it stumbles and dies out. It will do this anywhere from 5-10 times and usually pegging the throttle will get it going a little quicker. The check engine light flashes and it usually stumbles for 30 seconds before dying out. I even start and get under the hood and open the butterfly on the TB with no change. I have no other symptoms like some others such as dying in traffic or any changes if the air is turned on or off. I absolutely love this car and finally have it the way I want minus the Vertex, but I hate driving it only when I know I will not have to crank it back up. Like I said, when I searched..my symptoms pointed to dirty TB, but I cleaned it for two hours. It is spotless with the no sticking on the butterfly. TPS switched out with another unit and syptoms persisted. Cleaned AIC and is functional unless an electrical connection is dying out. Please Help me.
On a positive note, I did use the "DIY Door Handle Repair" write-up and took care of that last night
Mods, if this is not the right forum, please move but I figured this did not fall under "Performance".
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Disconnected batter and cleaned MAF out real good last night. Now it is a little worse with a new problem. Connected everything back up and started the car, but the check engine light stayed on. Figured it may go off so brought the car up to temp, let it sit for 5 monutes, and same thing with the stalling. It has always cranked back up and stumbled, but this time would not catch and acted like it was not getting any fuel. Started back up, check engine light still on and still stumbling to a stall. Anyone?????????
Bummer about your engine. This is probably too late to help, but here is a write up on resetting your ECU without disconnecting your battery.
http://web.ace.net.au/soarer/ecu_reset.html
Well, looks like the ECU finally relearned so everything is back to normal. Car idles perfectly with no check engine light, but still stalls after bringing up to temp. The car itself has 139k on it, but I am not sure if a failed fuel pump would only surface during warm starts. If I peg the gas to redline, it will not die on a warm start. There is no hesitation while driving and I went 300 miles just the other day. Everything works perfectly except trying to start it after it is warmed up. Thanks for the suggestions so far, but I might need to take it to a "stealership" and see if any codes are showing up.
************UPDATE************
Problem Fixed
Received a used Fuel Pump ECU from GRAND_LS 4 today. Drove home from work and let the car sit an hour. Went out to start it and it slowly stalled out. Tried again just to make sure and same thing. Switched out the "new to me" ECU from GRAND and it fired right up with no problem. It was such a simple fix. Seems like there were a lot of threads without any updates so hopefully if someone has a similar problem, they will see this thread after searching.
Problem Fixed
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
Problem Fixed
Received a used Fuel Pump ECU from GRAND_LS 4 today. Drove home from work and let the car sit an hour. Went out to start it and it slowly stalled out. Tried again just to make sure and same thing. Switched out the "new to me" ECU from GRAND and it fired right up with no problem. It was such a simple fix. Seems like there were a lot of threads without any updates so hopefully if someone has a similar problem, they will see this thread after searching.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Problem Fixed
Its such a relief to fix a car related problem, especially when you get it done with minimal financial, and physical effort.
Still trying to figure out whats going on with mine... its at the mercy of the dealer now. I'm still waiting for that call back
Enjoy your SC brother
HEY BRO... Glad it worked for you!!
Enjoy your SC brother![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
