Oil Filter For 1JZGTE
Old 03-21-07, 10:51 AM
LSEGHATCH
LSEGHATCH's Avatar
Default Oil Filter For 1JZGTE
Do 2jzgte oil filters work on the 1jzgte? If not, what should I use?
Old 03-21-07, 02:33 PM
blaznsc4
blaznsc4's Avatar
yes they will work.
Old 03-21-07, 02:34 PM
LSEGHATCH
LSEGHATCH's Avatar
Thanks for the fast reply.
Old 03-21-07, 02:36 PM
vinh
vinh's Avatar
yes, i use the 2jzgte one and i believe the part number is 3614 for fram oil filters
Old 03-21-07, 02:44 PM
XxSC400xX
XxSC400xX's Avatar
I would avoid using Fram oil filters. Check out this thread on Aftermarket Filters
Old 03-21-07, 03:11 PM
LSEGHATCH
LSEGHATCH's Avatar
Yeah I stay away from Fram....OEM usually
Old 03-21-07, 04:52 PM
got_trd
got_trd's Avatar
try using the search function next time. i know you got a new/used sc300 and probably dont know much about the 1jz yet but almost every question u will have has been discussed already
Old 03-23-07, 01:14 PM
Sc dRifta
*****Do not buy from this member until further notice *****
Sc dRifta's Avatar
use the ls400 oil filter from toyota its larger
Old 03-23-07, 02:07 PM
vinh
vinh's Avatar
damn didnt know all that about fram filters, thanks for the heads up
looks like its oem toyota for me
Old 03-23-07, 08:22 PM
Psionic
Psionic's Avatar
There is no minimum spec for an oil filter. It just has to fit and have a little bit of paper in it to call it a filter. Frams are notorious for collapsing and stopping up the oil system, which will cause a tapping noise at start-up to full blown engine failure if left long enough.
I would stick with OEM filters on any vehicle I own. They are actually "made to spec" for the various vehicles and are better quality than any aftermarket filter.
leehom
NX - 1st Gen (2015-2021)
10-01-22 09:17 AM
bollywoodk
Performance
23
09-19-06 08:19 PM
XxSC400xX
02-01-06 09:17 AM
CDE BRKR
Maintenance
01-19-04 02:32 PM
Quick Reply: Oil Filter For 1JZGTE
