DIY Cold Air Intake
#32
its all about functionality for me...by the way, it was $14...,plus tax
don't worry, nothing crazy this time, will definately go KrazeMatik's route, but definately with bigger pipes.
#33
is the plastic cover in the wheel well put back to normal or is there still a big opening in there? Looks like a great idea, and do you have to use the injen top pipe for this to work?
#34
i don't think it HAS to be Injen, in fact, you could also make the Injen part the same way the rest of it was made, just gota get the right bends. and your better off having the plastic cover back in place, you get enough air from the front.
#35
I has an intake mounted just like that. I never went through deep water. One day I was driving on the highway, behind an eighteen wheeler, and just the water being blown up from the road accumulated and made its way up through the piping. And,... HYDROLOCK!
Luckilly it didnt hurt anything. After I had it towed home I was able to pull the tb, and clean out the manifold, pull the plugs and crank it over.
Bottom line, ..I would NEVER run one again.
Second off, do you even know what hydrolock is?
Third, Hydrolock causes horrible damage to an engine, usually resulting in a bent rod or something of that nature....
#37
i agree with ant...i had a crx and had a custom aem cold air downpipe(too low) . one day it rained and i went into a puddle and water gulped plenty of water inside...it just stalled then i cranked it up and it started. dunno about "hydrolocking"
Wald GS
GS - 1st Gen (1993-1997)
24
06-18-03 12:23 PM
