OMG help (help = cant pull the crank pulley bolt out)
The starter bump method has worked fine for me a couple of times on my supra. Lay in front of the front bumper and rotate the crankshaft clockwise until the bar is firmly positioned on the ground. Have a buddy bump the key. Unless the bolt is overtorqued or corroded, it will break loose. Tightening that ***** to 239 ft/lb is a different story though, without something to hold the crank or removing the radiator to use an impact....
Sewpra
54
03-02-14 08:19 PM
