Fuel Tank Pressure...
Old 04-04-07, 06:03 PM
Redical
Redical's Avatar
Default Fuel Tank Pressure...
I've noticed that the past 3 times I've put gas in my SC4, when I unscrew the gas cap, there is no pressure releasing at all, no hissing or anything. Before, when I unscrewed the cap the pressure would almost push the cap off itself. Is this a problem or maybe just weather related? I haven't noticed anything else wrong, I did get a faint smell of gas the other day when I turned the car on with my door open, smelled unburned but I might be wrong. Any input would be much appreciated. Thanks
Old 04-04-07, 06:12 PM
over40driv
over40driv's Avatar
I have heard a lot of people on CL say you should buy a new gas cap, I suppose it is an update or just new, around $16.00.
Old 04-04-07, 07:42 PM
2JZ_SC
2JZ_SC's Avatar
The car will check to see if the fuel system is intact. It will pressurize the system and check for leaks. If there is a leak found it will turn on the "check engine" light and store a DTC in the ECU. Log and short of it. No light, no problem.
Old 04-05-07, 02:38 AM
Redical
Redical's Avatar
"No light, no problem. "
Thank god for sensors and other thing-a-majigs.
I think I'll buy a new gas cap just to be safe, from what I've read it can help with gas mileage, makes no sense to me but my wallet might appreciate it.
Old 04-17-07, 09:11 PM
ScottURnot
ScottURnot's Avatar
Location: Sideways on the Yellow Brick Road! < Thats KS!
Is there a way to clear the code?
Old 04-20-07, 05:11 PM
2JZ_SC
2JZ_SC's Avatar
Pull the EFI fuse for about 30sec. This will not work on 2002 and newer if I rember correctly.
FiveSeven
08-08-16 02:07 PM
Bankswood
03-09-16 01:54 PM
Jeffrimerm
05-01-14 01:03 PM
mian
Hybrid Technology
02-26-14 11:22 AM
NSeagle78
04-26-10 07:39 PM
Quick Reply: Fuel Tank Pressure...
