sc4 sitting for month in winter now problems?
Something has to fire those plugs. My '92 sure seems to have coil packs.
there are two ignition coil packs. my mechanic checked the wires, plugs, caps, rotors, crankshaft position sensor, and more... he needs an oscilliscope to check the ecm. i think it might be the computer?
anyway my mechanic didn't fix a thing and now im gonna tow the car to my house and try to crack it myself.
i have the repair manual but don't know where to start.
theres a section of codes which is prob the first thing i will do... its really annoying. what a waste of a pimp ride.
Try PM'ing Aliga as he can probably get you an ECM at a good price.
listen bro. when i did the body work on my car it sat 4 months. when i started it same prob. change both coil packs. you have 2. do a search on where they are. should run good after that. the coil packs are cheap enough. good luck
Sleeper97
Performance & Maintenance
08-14-05 02:47 PM
