1jz swap questions
1jz swap questions
alright first i blew my motor and wanna go with the 1jz swap. im wondering does anyone know any sites i can find one or have one with full uncut wireing harness and computer and if possible the 5 speed tranny and what all it takes to do the 5 speed swap but if not its ok i just mainly need the motor if anyone could help it would be greatly appriciated
thanks
thanks
You can use your stock ECU, I also heard you can use the mk3 supra non turbo and turbo tranny. If you go with the non turbo mk3 tranny (w58) you can use your auto bellhousing. If you find a tt mk3 tranny (r134?) you'll need either the 1jz or 2jz TT belhousing..
My motor has about 190k miles on it, I think it's on its way. I just bought a TT 1jz motor with harness, for 700 shipped to my door.
sorry for the drunk post haha
Last edited by yelloa3gti; 04-22-07 at 09:19 AM. Reason: CAUSE I WAS A DRUNK *******
what doesn't make sense about it. ??? Learn how to spell before you make a comment. If I'm wrong about something, correct it, simple. I'm only going on the research that I'd seen from other sites.
Since the org posting was asking about a motor I'm only giving my opinion.
What I'm referring to is my motor (my stock 2jz-ge) motor is about to blow, I'm hearing noises and all sorts of other **** from that motor. I'd stated I BOUGHT A 1jz MOTOR FOR $700 shipped to my door. Now what doesn't make sense about it, or obviously you can't read.
2, if you're speaking about the transmission combo, then clarify which parts are needed to complete the 5speed swap then to tell me it doesn't make any sense. ty
woah, settle down. for your transmission question, if you want to use the supra mk3 r154 you need the 1jz bellhousing found here
http://store.driftmotion.com/index.p...ory_id_int=136
