Crank Bolt Removal
Crank Bolt Removal
Guy last night I spent about 3 hours trying to get the dam thing off, try just about every thing, and the only combination that worked was PB BLASTER and a 1/2in impact gun @ 150 PSI with a few drops of hydraulic fluid in the gun. But to fit the 1/2in impact u need to remove the radiator and the shroud, shouldn’t take you more than an hour / hour and a half.
I'm having this problem right now. Unfortunately, the engine is out of the car and the cam gears are removed...
I tried 150PSI, but I used Tri-Flo. I will spray it with PB Blaster tomorrow and see if it will work.
damn, i'm still looking for a crank pulley. any thoughts for east coast would help..
-thanks
ps. so many ways in doing this.. i think i'll do it the getto way and start the car with the rod on the ground..(o-boy)
-thanks
ta1972
10-25-07 09:15 AM
Blk97SC300
Performance & Maintenance
17
03-29-07 07:00 AM
