How to remove the ECU?
Old 04-17-07, 09:36 PM
jacobzking
jacobzking's Avatar
Default How to remove the ECU?
I know the ECU is under the passanger seat, but do you actually need to remove the seat? anyone wanna give me a walkthrough? TIA!
Old 04-17-07, 09:42 PM
SC4V1
SC4V1's Avatar
go here: http://www.luxurymods.com/tutorial5.htm
hope it helps.
Old 04-17-07, 09:46 PM
jacobzking
jacobzking's Avatar
what is the other box by the main ECU?
Old 04-17-07, 09:52 PM
audi2nr
audi2nr's Avatar
abs
Old 04-19-07, 04:29 PM
Oz Man
Oz Man's Avatar
So the SC 300/400’s have the ECU under the front passenger seat? Mine is in the floor under the dash on the passenger side of my Soarer.
Old 04-19-07, 05:47 PM
audi2nr
audi2nr's Avatar
its not under the seat, its under the pass. side floor board close to the firewall. basically its the same as your soarer but on the other side
Old 04-19-07, 05:48 PM
SUPRMSC
SUPRMSC's Avatar
Remove passenger side molding and carpet, unhook the three main connectors on ECU, unbolt, and you're done.
Old 04-20-07, 05:16 PM
2JZ_SC
2JZ_SC's Avatar
Make sure you are grounded before handling the ECU. (I poped one when I worked for FORD)
jayclapp
SC- 1st Gen (1992-2000)
08-29-11 04:27 PM
mkaye
12-22-09 02:33 PM
grindin8o8
11-22-09 06:11 AM
DroppedGS
GS - 1st Gen (1993-1997)
02-26-03 08:40 AM
retrodrive
05-16-02 04:29 PM
Quick Reply: How to remove the ECU?
