View Poll Results: how long did it take you to get your 1jz swap in?
never really finished
15.71%
a few weeks
25.71%
a few days
37.14%
i dont get dirty my mechanic does
21.43%
Voters: 70. You may not vote on this poll
for the 1jz swappers
Old 04-18-07, 01:19 PM
ATL-SC
ATL-SC's Avatar
Default for the 1jz swappers
just curious how long it took you guys to get the swap done?
i think once finals are done im finaly diving in so i just wanted to get an idea.
oh and if you could post things that might have added alot of time to your swap like "auto to manual" or missing parts, things of that nature. And even a little back ground as to your mechanical prowess or friends that helped out would be cool too. im just trying to see where the CL comunity is at.
Old 04-18-07, 02:19 PM
yelloa3gti
yelloa3gti's Avatar
From driving my car into the garage to when its started with the 1J was about 15 hours. It still needs another half of day of work to be road worthy. I am just too busy with school to get home for a day to finish the little things up.
At the same time I also did a waterpump, timing belt, tensioner, thermostat, plugs etc etc. The timing belt alone took a good amount of time. ( probably took about as much time as the swap itself haha )
Its truely a very easy swap
Old 04-18-07, 02:26 PM
CCC-TT
CCC-TT's Avatar
im glad someone startde this thread because i was wondering about this too. i would like to know about the wiring issue as well, i have heard dropping the motor in is nothing, its the wiring thats a *****. it would be nice to have and idea of what im getting myself into.
Old 04-18-07, 02:34 PM
yelloa3gti
yelloa3gti's Avatar
I spend a couple months searching the forums and studyin up on the swap. I recomend everyone do the same. There were lots of shortcuts and certain things I learned from doing research that otherwise I wouldnt have known. The wiring is easy. You simple have to extend the body plugs about 20 inches. Its somewhere around 40 wires. Simply cut one at a time and extend. Its time consuming ( about 3 hours ) but its not hard
Also search for a thread I started (Yelloa3gti) named "my 1jz swap" Alot of helpful tips from people on there
Old 04-18-07, 05:04 PM
ATL-SC
ATL-SC's Avatar
thanks yelloa3gti i saw your thread this morning and it was very comprehensive. i do have one question for you; how did you deal with the driveshaft? because it seems to be one of the last itemes i just cant seem to find a definative answere on.
Old 04-18-07, 06:01 PM
Psionic
Psionic's Avatar
Drove in on Saturday morning, drove out Sunday afternoon.
Its not as easy as people say it is though.
Old 04-18-07, 06:10 PM
plex
1UZFE/2JZGTE
plex's Avatar
Mine took longer because it wasn't worked on everyday. I drove my car to NY from MD for the swap. Had some issues but considering I drove back four hours with the motor and no issues I would say it went well. Even got 200 miles on barely half a tank. In the meantime my single conversion is taking forever ha ha.
Old 04-18-07, 07:30 PM
97-SC300
97-SC300's Avatar
what did you guys do about the knock sensor wires all i heard is about some kind of shielded USB wire you have to use, any more info would be great.
Old 04-18-07, 07:40 PM
yelloa3gti
yelloa3gti's Avatar
If you are using the stock w58 then you use your same driveshaft. I went with a soarer r154 so i had to use the front half drive shaft from a mk3 supra turbo
Old 04-18-07, 07:42 PM
yelloa3gti
yelloa3gti's Avatar
Nothin.. dont touch it.. just extend body plugs
atekt
atekt's Avatar
It is a pretty straight forward swap, I have done two with just me and a buddy. My only deal is I cant figure out what is going on with mine now since the new 1j was put in. Cranks but no start... Real bummer.
atekt
atekt's Avatar
Blair, Where did you find your Soarer R154??
Old 04-18-07, 08:03 PM
yelloa3gti
yelloa3gti's Avatar
got a soarer 5 speed motorset from JHOT
Old 04-18-07, 09:18 PM
RaynArt
RaynArt's Avatar
if i used the soarer auto it would just drop right in right?
Old 04-18-07, 11:24 PM
cino78h
cino78h's Avatar
i were woudering can the w58 yoke pigtail fit onto the r154?if so would that be cheaper and easy part to finds?
Quick Reply: for the 1jz swappers
